Problems with 5.5
onlypirc
Problems with 5.5
Unread post by onlypirc »
Release 5.5 simply doesn't work for me. Any song that's already cached won't play - songs that are streaming directly are playing ok. If I have a play list where some of the songs are preloaded, I can skip to any song that's not marked yet and it will play, go back to any that are already on the device and it just sits there. After a short while all my songs are on the device and none of them play any more.
I went back to 5.4 and everything works fine. Upgraded to 5.5 and again it's all broken. Apparently a new bug was introduced.
onlypirc
Re: Problems with 5.5
Tried the new version through early adapter program - still the same problem with 5.6
Dev - any response? Plans to fix this bug? Do you need more info, logs? Kinda frustrating to have a non-working app (that I paid for)....
Can you please provide more information about your phone, Android version, ROM version, rooted ?
Maybe a complete app cleanup/uninstall/reinstall will help to set the cache folder right for your rom.
does the problem still exists?
