Wanting to play with some source code modifications, i figured out that Madsonic (and Subsonic as well) comes precompiled and in order to be able make some local modifications i have to use JDK version of Java, not only JRE. So i completely uninstalled Madsonic, Java JRE that came with it, rebooted (my OS is Win7 64bit) and installed latest Java 7 JDK (jdk-7u51-windows-i586.exe). 32bit because i'm going to use 32bit browser with Madsonic. Everything installed OK, so now i've got:
- usual JRE located in c:\Program Files (x86)\Java\jre7\
- devkit JDK located in c:\Program Files (x86)\Java\jdk1.7.0_51\
To test that all things are ok, i commented out main.jsp in web.xml file according to this manual: http://forum.subsonic.org/forum/viewtop ... 11&t=10783 and i get the following error:
Exception org.apache.jasper.JasperException
Message PWC6345: There is an error in invoking javac. A full JDK (not just JRE) is required
Java version Oracle Corporation 1.7.0_51
Operating system Windows 7 6.1
Server jetty/8.y.z-SNAPSHOT
Memory Used 152 of 247 MBAny suggestions would be very appreciated
