Cannot launch Madsonic 5 on Freenas (SOLVED)
raidflex
Been thanked: 6 times
Unread post by raidflex »
I have also posted this issue on the Freenas under plugins/Subsonic plugin.
I followed the Freenas 8.3.1 guide for installation of Madsonic on the subsonic forums.
After installing Madsonic 5, all dependencies and configured the subsonic.sh configuration file I attempted to launch subsonic.sh but receive the error below and the application will not launch.
Error: 18: Syntax error: word unexpected (expecting ")")
I have double checked my subsonic configuration file multiple times and all settings are correct.
Please advise. Thanks.
I could not add any website links to the Freenas forums and the guide I used for Madsonic setup on Freenas because apparently these are considered "spam" by the forums here.
Re: Cannot launch Madsonic 5 on Freenas
raidflex wrote:I have also posted this issue on the Freenas under plugins/Subsonic plugin.
It is already a while ago that I've tested Madsonic on Freenas, but it worked. Which Java Runtime did you use?
PS: Yes this forum is SPAM-protected, you should now have unlimited access.
raidflex
I was actually able to fix the issue. Subsonic did not like the use of certain characters in the subsonic.sh file that I used for my Playlists and Podcasts folder names.
So now the server launches okay after changing the names to all letters.
These users thanked the author raidflex for the post:
