Running the newest Android APK file (4.0.9 I believe), and there's an issue with the "reflection" component of the album art.
Apparently, while the album art changes from song to song, the "reflection" just overlays what was there before. For the first song, this is OK, since there was nothing there initially, but for the second and following songs, the reflection of the new album art just overlays what is already there.
Running the first 5.0 beta FYI, in case the issue is server related...
Madsonic Android Client 4.0.x Reflection Background [Solved]
- Been thanked: 105 times
Re: Madsonic Android Client 4.0.x Reflection Background
Found a "workaround" of sorts.... Just let the display rotate from landscape to portrait mode, or the other way around, and then back again, and the reflection will "reset" to the current album cover (until the next song starts playing).
It's fixed in the Android 5.0 Release, which will be released soon.gurutech wrote:Found a "workaround" of sorts.... Just let the display rotate from landscape to portrait mode, or the other way around, and then back again, and the reflection will "reset" to the current album cover (until the next song starts playing).
