I am running alpine-madsonic idocker image on a Synology NAS as I could not find a Synology plugin (SPK) package.
Any way the docker image is quire old (about 4 years) and I was wondering if there is a more recent image ideally with madsonic 7 on it.
I have been troubleshooting an issue with no artist images which according to google is because of a missing class of the java sdk. Obliviously not something I can fix myself and probably a result of how out of date the docker image is.
I am very keen to see how version 7 compares and thinking about signing up for lifetime access.
Regards,
Greg.
Where can I find the most rercent Docker image?
joethelion
- Been thanked: 0
jason4bury2
- Has thanked: 4 times
- Been thanked: 1 time
Re: Where can I find the most rercent Docker image?
Here's a version I found earlier this week that runs in docker.
Version 7 Docker :-
https://registry.hub.docker.com/r/log1x/madsonic/
I've installed it on my Synology box and it runs just fine
Version 7 Docker :-
joethelion
- Been thanked: 0
Thanks for the info.
I have installed the container and although the container starts up, I cannot scan any media folders. From looking at the log it appears to be a permissions issues.
I have specified a valid user and group in the PUID and PGID environment variables but it looks like these are ignored by the running container. I have tried using UID and GID but that doesn't work either.
Any chance you can share you docker configuration.
jason4bury2
Here your are :-
Ports
Local Port Container Port type
4040 4040 tcp
4050 4050 tcp
Network
Network Name Driver
bridge bridge
Volumes
File/Folder Mount Path Type
docker/madsonic /data rw
music /music rw
Environment
Defaults plus the following :-
PUID 1000
PGID 1000
TZ Europe/London
Here your are :-
Ports
4040 4040 tcp
4050 4050 tcp
Network
Network Name Driver
bridge bridge
Volumes
music /music rw
Environment
PUID 1000
PGID 1000
TZ Europe/London
