$ /Applications/Madsonic.app/Contents/MacOS/universalJavaApplicationStub
ago. 10, 2018 9:10:47 P. M. org.springframework.context.support.ClassPathXmlApplicationContext prepareRefresh
INFORMACIÓN: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@cd2dae5: startup date [Fri Aug 10 21:10:47 CEST 2018]; root of context hierarchy
ago. 10, 2018 9:10:47 P. M. org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFORMACIÓN: Loading XML bean definitions from class path resource [applicationContext-mac.xml]
ago. 10, 2018 9:10:51 P. M. org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFORMACIÓN: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@6a03bcb1: defining beans [deployer,frame,controller]; root of factory hierarchy
used forced Install_Dir = /Library/Application Support/Madsonic
ERROR: The directory /Library/Application Support/Madsonic does not exist. Please create it and make it writable. (You can override the directory location by specifying -Dmadsonic.home=... when starting the servlet container.)
Using WAR file: /Applications/Madsonic.app/Contents/Resources/Java/madsonic.war
Extracting webapp to /Library/Application Support/Madsonic/jetty/9040
Failed to create directory /Library/Application Support/Madsonic/jetty/9040
java.lang.IllegalArgumentException: Bad temp directory: /Library/Application Support/Madsonic/jetty/9040
at org.eclipse.jetty.webapp.WebAppContext.setTempDirectory(WebAppContext.java:1119)
at org.madsonic.booter.deployer.MadsonicDeployer.deployWebApp(MadsonicDeployer.java:220)
at org.madsonic.booter.deployer.MadsonicDeployer.<init>(MadsonicDeployer.java:100)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:488)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:938)
at org.madsonic.booter.Main.main(Main.java:82)Code: Select all
java.lang.IllegalArgumentException: Bad temp directory: /Library/Application Support/Madsonic/jetty/9040The server doesn't starts. I do not know what else I can do.
