HTTP ERROR: 503
Service Unavailable
Uncertain where to go from here. Here are the logs from /var/madsonic/
Nov 16, 2017 12:19:54 AM org.springframework.context.support.ClassPathXmlApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1d451d2: startup date [Thu Nov 16 00:19:54 EST 2017]; root of context hierarchy
Nov 16, 2017 12:19:54 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
Nov 16, 2017 12:19:54 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@13ab52c: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
No newer update found.
Extracting webapp to /var/madsonic/jetty/9720
2017-11-16 00:19:54.871:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
2017-11-16 00:19:54.904:INFO:oejw.WebInfConfiguration:Extract jar:file:/usr/share/madsonic/madsonic.war!/ to /var/madsonic/jetty/9720/webapp
2017-11-16 00:20:01.129:INFO:/:Initializing Spring root WebApplicationContext
[2017-11-16 00:20:02] [WARN ] [main] XmlWebApplicationContext - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerDao' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'daoHelper' while setting bean property 'daoHelper'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'daoHelper' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static org.madsonic.dao.DaoHelper org.madsonic.dao.DaoHelperFactory.create()] threw exception; nested exception is java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
[2017-11-16 00:20:02] [ERROR] [main] ContextLoader - Context initialization failed
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:334)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:638)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:942)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:482)
at org.madsonic.booter.deployer.MadsonicDeployer.deployWebApp(MadsonicDeployer.java:247)
at org.madsonic.booter.deployer.MadsonicDeployer.<init>(MadsonicDeployer.java:102)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.madsonic.booter.Main.<init>(Main.java:46)
at org.madsonic.booter.Main.main(Main.java:85)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'daoHelper' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static org.madsonic.dao.DaoHelper org.madsonic.dao.DaoHelperFactory.create()] threw exception; nested exception is java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:603)
... 49 common frames omitted
Caused by: org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static org.madsonic.dao.DaoHelper org.madsonic.dao.DaoHelperFactory.create()] threw exception; nested exception is java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:181)
... 58 common frames omitted
Caused by: java.lang.UnsupportedClassVersionError: org/hsqldb/jdbcDriver : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:421)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:383)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:274)
at org.springframework.jdbc.datasource.DriverManagerDataSource.setDriverClassName(DriverManagerDataSource.java:147)
at org.madsonic.dao.HsqlDaoHelper.createDataSource(HsqlDaoHelper.java:109)
at org.madsonic.dao.HsqlDaoHelper.<init>(HsqlDaoHelper.java:56)
at org.madsonic.dao.DaoHelperFactory.create(DaoHelperFactory.java:41)
... 59 common frames omitted
2017-11-16 00:20:02.402:WARN:oejw.WebAppContext:Failed startup of context o.e.j.w.WebAppContext{/,file:/var/madsonic/jetty/9720/webapp/},madsonic.war
Caused by:
Caused by:
Caused by:
2017-11-16 00:20:02.434:INFO:oejs.AbstractConnector:Started @0.0.0.0:4040
Nov 16, 2017 12:20:02 AM org.springframework.remoting.rmi.RmiServiceExporter getRegistry
Nov 16, 2017 12:20:02 AM org.springframework.remoting.rmi.RmiServiceExporter prepare
INFO: Binding service 'MadsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.0.1:9412](local),objID:[0:0:0, 0]]]]
