CLIENT/BROWSER: FF 53.x, Safari
REPRODUCIBLE: yes
It does not work here too.
To make it more clear, screenshots will help 8-)
- this settings has no effect (even if reloading the webpage, or logout-logon again). The left bar keeps expanded, and does not start shrinked. (also not, if the webpage is reloaded via a configuration change, say, changing the language)
- shrinking(and unshrinking) works as expected, if clicking the button.
- LeftBar shrinking via button works fine.png (18.43 KiB) Viewed 33860 times
Cache was cleared, tried with different browsers on different OS (Win/Mac, FF, Safari)
EDIT: Aha, I found out, that its not working with the standard Admin account. If I log in as a normal User, the Bar is shrinked at the start.
