Take this example... The docker host is at 192.168.1.3 and I access Madsonic by going to 192.168.1.3:4040 because the 4040 port is forwarded to the docker container.
When turning on Sonos in Madsonic, I see the following in the logs...
[8/16/17 12:14 PM] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.1.53, SID 244, presentationMap 15, stringVersion 8, and Madsonic URL http://172.17.0.1:4040/ws/Sonos172.17.0.1 is the IP that Docker assigns to Madsonic. Sonos should actually target 192.168.1.3.
I know that the Docker really doesn't know the host IP... so what I would like to see is a way to override this IP in the madsonic.properties file.
This was tested on 6.3.9540.3e2ad42.20170703.120 (the latest on the docker betas)
