Sonos on Synology-- Can´t connect
jflocke
Unread post by jflocke »
i am running my synology DS415+ on DSM 6.0.2-8451 Update 9.
Madsonic is running on MADSONIC 6.2.9080.619dd31.20161222.0327 .
Sonos is on 7.2 - 35339010.
When i try to add Madsonic as a service in Sonos, i always get the problem that i can´t connect to sonos.
25.05.17 12:59] INFO SonosService Found Sonos controllers: [192.168.0.76, 192.168.0.79, 192.168.0.17, 192.168.0.25, 192.168.0.29, 192.168.0.18, 192.168.0.30, 192.168.0.27, 192.168.0.14, 192.168.0.23]
[25.05.17 12:59] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.76, SID 244, and Madsonic URL http://172.17.0.1:4040/ws/Sonos
[25.05.17 12:59] INFO SonosServiceRegistration Sonos controller returned: success!
I guess that there is a problem with the madsonic url.. i don´t know where to change it.. can any1 help me out here? do you need any more information?
thank you so much.
julian
These users thanked the author jflocke for the post:
Re: Sonos on Synology-- Can´t connect
try to bring the Madsonic server to the same ip subnet (192.168.0.x) Sonos products can't broadcast to different subnets.
to config your Madsonic url rewriter go to Settings > Network
jflocke
thanks for your help. I tried to change it but get the following error:
Status: Could not connect to http://192.168.0.38:4040. (HttpHostConnectException)
can you help me out here?
thank you so much
