Scrollbar missing for left panel in Chrome
JoeDat
Has thanked: 3 times
Unread post by JoeDat » 10 Jan 2017, 23:29
The scrollbar isn't present for the left pane when using Chrome. It's there in Internet Explorer and Firefox. Haven't tested others. I can scroll down the list by highlighting the icons and dragging off the window, which is obviously pretty wonky.
Running beta 6.2.9080.
troycarpenter
Has thanked: 22 times
Been thanked: 49 times
Re: Scrollbar missing for left panel in Chrome
Unread post by troycarpenter » 11 Jan 2017, 16:56
I almost posted on this the other day, however I noticed that when I clicked (or pointed) into that frame and used the scroll wheel on my mouse, the menu scrolled for me. I was also able scroll with the arrow keys. I'm not sure if the scrollbar is missing due to a bug or due to aesthetic reasons.
JoeDat
JoeDat
Unread post by JoeDat » 11 Jan 2017, 22:13
Good call on the arrow key option. Works for me as well. My gut tells me that it's a bug since it's present in other browsers.
Has thanked: 1147 times
Been thanked: 448 times
Unread post by Madsonic » 23 Jan 2017, 22:47
JoeDat
JoeDat
Unread post by JoeDat » 23 Mar 2017, 13:38
Hey, curious if "next release" means the next stable release? I've gone through a few beta upgrades and I'm currently running build 6.2.9260. Issue has persisted.
