Can you show any logs?
You can SSH with Putty on your Synolgy. On directory var/packages/Madsonic/target are the logs.
https://www.synology.com/en-global/know ... m_terminal
carlosarze
- Has thanked: 1 time
- Been thanked: 2 times
I wasn't able to install , there is nothing on that path....
the only thing is a log in the root directory
08.04.16_12:23:02: found Java in /volume1/@appstore/java8/ejdk1.8.0_77/linux_i586/jre
08.04.16_12:23:02: Can't find a folder named 'Madsonic' in your public folder.
08.04.16_12:23:02: Please check your public folder and make sure there is a folder called Madsonic (with Capital M) in it. Or select 'No' if you don't want to restore anything and just install Madsonic normally
- These users thanked the author carlosarze for the post:
carlosarze
@Madevil is there any hope to see Madsonic on Synology DSM 6.X ?
HolgerWill
- Been thanked: 3 times
Madsonic Folder not found --- Solution?
I had the same issue. Madsonic folder was not found in public.
I opened the spk file in 7zip.
In folder "scripts" I opened the file installer.sh with notepad++
Then I modified line4 to..... PUBLIC_FOLDER="/volume1/public"
After that the installation run through
- These users thanked the author HolgerWill for the post (total 3):
- Madsonic • carlosarze • muiz
- Rating: 23.08%
carlosarze
Re: Madsonic Folder not found --- Solution?
Thank you very much using 7zip did the trick I didn't realize that using winrar was not saving the modified installer.shHolgerWill wrote:I had the same issue. Madsonic folder was not found in public.
Anyway Madsonic is installed now and seems to be working ....
Thanks again !!!
can you please upload your file?carlosarze wrote:Thank you very much using 7zip did the trick I didn't realize that using winrar was not saving the modified installer.shHolgerWill wrote:I had the same issue. Madsonic folder was not found in public.
Thanks again !!!
madschwall
- Been thanked: 0
Thanks, the trick with editing installer.sh did the job.
I had to reboot the NAS then everthing is running like a charm.
Never mind i got it. it installed fine now thank you.
EDIT: It started but the page wont show up. So its still not working for me.
EDIT 2 : Reinstalled DSM now it works.
HolgerWill
Yes this is right. I forgot to mention this point.madschwall wrote: I had to reboot the NAS then everthing is running like a charm.
Rebooting is necessary.
Nice to see that I could help some members here.
Note! A new version is available. Download Madsonic 6.1.8220 HERE.- Madsonic
Re: AW: Madsonic Server 6.x Synology-DSM 6.x NAS Plugin
What is refactor left-panel?Madevil wrote:Take a look at
http://beta.madsonic.org/pages/changelog.jsp#6.1.8220
Is the playlist on left-panel fixed also with this update?
softsmoke wrote:Hello all
i installed the latest version. Now i cant see my library in DSUB. can somebody tell me why? its says No data!!
/Softsmoke
Same here.
Rest API fix is included in the last build 8280.
HolgerWill
Backup Database .. HOW?
Everytime I deinstall the old version in DSM I select "Make Backup in Public"
But while installing the new version with "restore Backup" it is not working.
It is all blank new. No restoring of anything!!
Is there any solution?
carlosarze
Installed the last version and does not work ...
HTTP ERROR: 503
Problem accessing /. Reason:
Service Unavailable
HTTP ERROR: 503
Service Unavailable
Anyone else who tried the new version?
Its really hard to get it working. It doesnt install out-of-the-box anymore.
I am using 6.1.8190 atm, but last time i had such a hard time to get it installed again. Dunno how to get the new version on it, and will it be the same pain installation as last time?
tofuSCHNITZEL
- Been thanked: 1 time
after manually creating the Madsonic folder in public the install worked fine with Madsonic6.1-B8550-048.spk
should the videostreaming work? I only get a white screen with following text:
http://NAS:4040/hls/hls.m3u8?id=4&playe ... tRate=3000
tried in FF, IE and Edge. the latter two also display the whole interface not correctly so starting the stream is a little difficult (lowest frame takes up about 80% of screenspace)
VLC is installed
DS1813+
DSM 6.0.1-7393 Update 2
VLC is installed
DS1813+
