Ive got this weird issue, some songs will only play for about 1 second, and then it skips to the next one.
However if play it about 3 seconds in, its fine.
this effects certain songs, 100% of the time.
Any ideas?
Song skips after 1 seconds
Re: Song skips after 1 seconds
Switched to debug
[1/10/15 12:45 AM] INFO PlayQueueInputStream ProtoJazz listening to "Reise, Reise/06 Amerika.mp3"
[1/10/15 12:45 AM] DEBUG AudioScrobblerService Successfully registered now playing for song 'Amerika' for user RelicOfEarth at Last.fm: Sat Jan 10 00:45:26 CST 2015
[1/10/15 12:45 AM] DEBUG AudioScrobblerService Successfully registered submission for song 'Amerika' for user RelicOfEarth at Last.fm: Sat Jan 10 00:45:27 CST 2015Re: Song skips after 1 seconds
[10.01.15 12:33] INFO PlayQueueInputStream DoCC listening to "Reise, Reise/Reise, Reise.flac"
[10.01.15 12:33] DEBUG TranscodeInputStream Starting transcoder: [/var/madsonic/transcode/ffmpeg] [-i] [/mnt/audio/R/Rammstein/Reise, Reise/Reise, Reise.flac] [-map] [0:0] [-b:a] [128k] [-v] [0] [-f] [mp3] [-]
[10.01.15 12:33] DEBUG AudioScrobblerService Successfully registered now playing for song 'Reise, Reise' for user BlueScreenDevel at Last.fm: Sat Jan 10 12:33:48 CET 2015
[10.01.15 12:33] DEBUG AudioScrobblerService Successfully registered submission for song 'Reise, Reise' for user BlueScreenDevel at Last.fm: Sat Jan 10 12:33:54 CET 2015you see the trancsoder is starting ... no matter what file type.
your transcoder does not fire up.
check the transcoding settings of your player.
if you only listen to music you can disable the entire movie settings.
then JUST enable one transcoder, test it and repeat.
my stuff only works with music-> mp3 and wma
