Post by Madsonic »
thanks for reporting, i will recheck the plugin for the Gotham release.
muiz
Has thanked: 4 times
Post by muiz »
Tried to install in Gotham 13.2 Image But it wont start.
skopo
Has thanked: 8 times
Been thanked: 16 times
Post by skopo »
muiz wrote:Tried to install in Gotham 13.2 "picture" But it wont start.
Just installed new setup on OSX 10.9.4 and XBMC 13.2.
Installed just fine. Song problem remains...
Have to stream over FTP (pain in the ass)
Dylansama
Re: Madsonic Server 5.x XBMC Plugins
Post by Dylansama »
Wondering if anyone has had any success with last.fm scrobbling yet? I guess I had erroneously thought the Madsonic server would handle last.fm scrobbling, since that seems to work fine for me when using the web interface. Or is that only supported in certain clients? In other words not XBMC?
Anyways I installed the XBMC last.fm plugin (service.scrobbler.lastfm) but that doesn't seem to scrobble either from XBMC's side :(
On Gotham 13.2. No trouble installing or on playback though :)
These users thanked the author Dylansama for the post:
tokka
Post by tokka »
Hi all, same issue than Neilbla :(
the plugin works well, but it show only the the folders inside the main folder, and not the files....
so, if i share my home/user/video folder, with 5 files and 3 folders, i have access on the 3 folders content, but not at the 5 files, and same for music files.
Is possible to fix that? or we can only move files in new subfolder as workaround?
Tk
albebert
Post by albebert »
Audio plugin works great for me, but not the video plugin.
When I click on a video file.... Nothing append.
Any idea ?
