Hi I don't know if this is possible to do, but I want to remove the requirement for anyone to need to register in order to view/play playlist.
Basically when I go to my ip/port I get greeted with my music collection instead of a login page. And start playing music right away.
When I want to change settings or anything I can login page and login as admin to change settings, otherwise I won't need to login at all.
Is this possible with madsonic? I am pretty new madsonic so I obviously don't know how much customization is possible.
Thanks for any help.
Using Madsonic without user registration
Re: Using Madsonic without user registration
Normally I just check the 'Remember Me' or similar box and I usually am logged straight in after the first time.
btw
you can also use it with encoded passwords
Example http://www.madsonic.org/demo.html
http://yourhost/subsonic/login.view?user=guest&password=enc:34524523457374best regards
