If you add random songs to the queue from the More section, it will choose songs from folders that the user cannot view.
Am I right in assuming that this is because the folder permission feature is only hiding the folders from the list on the left hand side?
Access to folders not authorised
Re: Access to folders not authorised
the folder based access is a role based security implementation
https://github.com/MadMarty/madsonic-se ... Right.java
i will investigate this issue.
