Alnum-Folders instead of Tags
madsub
Been thanked: 19 times
Unread post by madsub »
I have tagged all my MP3s.
Nevertheless I have build a folder-structure out of my tags that mainly has the structure
Albumartist\Album\Sometimes Volume
What I want is, that madsonic cares about my folders ALBUMARTIST and ALBUM and not their equivalent tags.
My album-foldername sometimes is slight different fom the album-tag on purpose.
I cannot find a way that madsonic takes the name of the album-folder and that breaks my whole structure inside madsonic.
How can it be done?
Re: Alnum-Folders instead of Tags
this should really be the advantage of madsonic, maybe a parsing setting block this.
Can you give me a real example? Maybe a additional new setting can help in your case.
madsub
Madevil wrote: Can you give me a real example? Maybe a additional new setting can help in your case.
Sorry but it started working again like before and I donÄ't realy know the reason.
I have 2 installations, one for testing, the other as a working server.
Both were Build 3830 but one showed the album-tags and the other showed the folder-names. In both cases "Sort albums by foldernames" was enabled.
I disabled foldernames, enabled it again, made a rescan and suddenly the foldernames worked again.
These users thanked the author madsub for the post:
