transcoding fixes
Answers: 4
Has thanked: 1171 times
Been thanked: 457 times
transcoding fixes
Found a interesting note !
Commodore wrote:So, I've noticed in the last two versions at least (4.7 and 4.8 for sure; I don't recall if this was an issue in 4.6) that some FLAC files will not stream properly through the web interface. The file will transcode, but will not start playing until scrubbing past the first second of the track. This gets pretty obnoxious, but I figured out that it's a problem with the version of ffmpeg supplied with subsonic.
So, here's how I fixed it on my server, which is running Ubuntu 10.04, but this should work on any Ubuntu system certainly, likely any Debian system, and substituting the package manager commands for appropriate ones, likely any other Linux system as well.
This requires the "multiverse" repositories to be enabled on Ubuntu (in my case, lucid/multiverse, lucid-updates/multiverse and lucid-security/multiverse)
info: https://help.ubuntu.com/community/Repositories/Ubuntu
sudo apt-get install ffmpeg libavcodec-extra-52 libavdevice-extra-52 libavfilter-extra-0 libavformat-extra-52 libavutil-extra-49 libpostproc-extra-51 libswscale-extra-0
for Ubuntu 13.10
sudo apt-get install ffmpeg libavcodec-extra-53 libavdevice-extra-53 libavfilter-extra-2 libavformat-extra-53 libavutil-extra-51 libpostproc-extra-52 libswscale-extra-2
now either remove or rename the shipped ffmpeg package:
sudo mv /var/madsonic/transcode/ffmpeg /var/madsonic/transcode/ffmpeg-bak
and symlink in the system one:
sudo ln -s `which ffmpeg` /var/madsonic/transcode/ffmpeg
and you're done!
Answers: 4
Re: transcoding fixes
other transcoder
sudo apt-get install ffmpeg xmp lame flac
sudo rm /var/madsonic/transcode/ffmpeg
sudo rm /var/madsonic/transcode/lame
sudo rm /var/madsonic/transcode/xmp
sudo rm /var/madsonic/transcode/flac
sudo ln -s /usr/bin/ffmpeg /var/madsonic/transcode/ffmpeg
sudo ln -s /usr/bin/flac /var/madsonic/transcode/flac
sudo ln -s /usr/bin/xmp /var/madsonic/transcode/xmp
sudo ln -s /usr/bin/lame /var/madsonic/transcode/lame
Last bumped by Madsonic on 16 Aug 2015, 21:07.
hanshans
