I have tried a couple of versions of madsonic, but all with the same result: the dropdown next to offset, under the video plugin remains empty.
I tried switching to webm, but here the offset remains empty as well.
Factsheet:
OS: Debian
Tomcat 7
20131017_madsonic-5_Build_3760
java 1.7.0_21
The offset used to work under subsonic 4.8 on the same machine (be it with an older tomcat and java version), however I need madsonic for its multi-user capability.
Unable to seek in videos [Solved]
unnilennium
- Been thanked: 0
Re: Unable to seek in videos
Hello, i ran into the same problem for two location with only video in it.
this has drove me crazy as I kept on clisk on scan now and it remained empty.
solved it by doping a random mp3 in the folder and magically Madsonic accepted to scan the location !!
seems that Madsonic only scan vidéo if there is also music files with it ?
could it be a fix for that ?
linux SME Server- based on CentOS 5
smeserver-madsonic-5.0.3760-2
madsonic-5.0.3760-1
java-1.7.0-openjdk-1.7.0.45-2.4.3.1.el5_10
rpm made from madsonic-5.0.3760 version.
madsonic-5.0.3760-1
I don't know what I did on my installation. I did not include mp3 files, that is for sure.
I played a bit with WebM and back to flash and back to WebM and mixed in a rescan. And then it just worked. Even after the upgrade to build 3800 things are still working.
