Script to run War upgrade in the new Madsonic
chali
Has thanked: 18 times
Been thanked: 35 times
Unread post by chali »
This script is made by Marty, i have only made a small edit so it will work with the new Madsonic
Remember to run it as root and to use big letters (Y/N) when you answer the questions in the console,
When it asking for the built number it the last 4 numbers ( example 3660)
/Sincerely Chali
madsonicupdate.sh
Masonic War update script
(2.76 KiB) Downloaded 1133 times
nodename
Re: Script to run War upgrade in the new Madsonic
Unread post by nodename »
Can I use this script to upgrade from 5.x to 6.x? And will the Android client need to be changed as well?
This script is only for upgrading the server installation.
We working on a new transfer tool to migrate old data to the new Madsonic 6.3 database.
https://gist.github.com/MadMarty/2ed7f5 ... 04e19e4749
Stay tuned! ;)
nodename
Yes, I understand it's for the server. That's what the first part of my question referred to.
Can I use the script to upgrade the server from 5.x to 6.x?
What is the implication of your comment about migrating the data? Is upgrading the server with the script not sufficient?
Also is the current release of the Android client compatible with 6.x?
