I am running madsonic at work, but the network I am on is behind a proxy. I am unable to validate my license, and see the following error in the logs:
[2016-06-15 12:30:53,623] WARN SettingsService - Failed to validate license.
org.apache.http.conn.HttpHostConnectException: Connect to beta.madsonic.org:80 [beta.madsonic.org/52.1.190.210] failed: Connection timed out: connect
If I switch to another less secure network that does not have the proxy, then I don't see this error and I am able to validate my license. However this is not an ideal solution, I need to be on the secure network.
Is there another workaround?
