6.1 failing to create search index
garyo
Has thanked: 8 times
Been thanked: 17 times
Unread post by garyo »
 VERSION:      MADSONIC 6.1 | BUILD: 8120, STANDALONE
 SERVLET:      DEFAULT
 SERVER:       CPU: ICORE7 | ARCH: X64 | MEMORY: 16GB | HDD: 10TB
 OS:           FREEBSD
 SYSTEM:       NAS (FREENAS JAIL)
 INSTALLER:    STANDALONE
 JAVA:         OPEN JDK 1.8
 BROWSER:      CHROME 48
 CLIENT:       MADSONIC 6.1
 DESCRIPTION:  FAILED TO CREATE SEARCH INDEX
 REPRODUCIBLE: YES
Since updating from 6.0.7960 to 6.1.8120 this morning, media scans fill the log with this, for every song:
[2016-03-05 07:50:11,042] ERROR SearchService - Failed to create search index for Dancing With The Moonlight Knight
java.lang.NullPointerException
        at org.madsonic.service.SearchService.index(SearchService.java:146)
        at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:436)
        at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:479)
        at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:482)
        at org.madsonic.service.MediaScannerService.doFullScanLibrary(MediaScannerService.java:350)
        at org.madsonic.service.MediaScannerService.access$200(MediaScannerService.java:51)
        at org.madsonic.service.MediaScannerService$4.run(MediaScannerService.java:196)
and finally:
[2016-03-05 07:50:11,094] ERROR SearchService - Failed to create search index.
        at org.madsonic.service.SearchService.stopIndexing(SearchService.java:177)
        at org.madsonic.service.MediaScannerService.doFullScanLibrary(MediaScannerService.java:402)
Random album view no longer works. Playing still is fine, as are most of the screens (recent additions, view by artist, etc.)
Here's the stack trace for failing to search for random albums:
[2016-03-05 07:54:57,519] ERROR SearchService - Failed to search for random albums.
org.apache.lucene.index.CorruptIndexException: Unknown format version: -11
        at org.apache.lucene.index.SegmentInfos.read(SegmentInfos.java:249)
        at org.apache.lucene.index.DirectoryReader$1.doBody(DirectoryReader.java:77)
        at org.apache.lucene.index.SegmentInfos$FindSegmentsFile.run(SegmentInfos.java:677)
        at org.apache.lucene.index.DirectoryReader.open(DirectoryReader.java:73)
        at org.apache.lucene.index.IndexReader.open(IndexReader.java:316)
        at org.apache.lucene.index.IndexReader.open(IndexReader.java:202)
        at org.madsonic.service.SearchService.createIndexReader(SearchService.java:865)
        at org.madsonic.service.SearchService.getRandomAlbums(SearchService.java:715)
        at org.madsonic.controller.HomeController.getRandom(HomeController.java:470)
        at org.madsonic.controller.HomeController.handleRequestInternal(HomeController.java:189)
...and lots more...
Re: 6.1 failing to create search index
Thank you for reporting this issue. This is fixed with the upcoming version.
Workaround
Please stop the server and delete the folder from this path /var/madsonic/lucence3,
restart your server and trigger a full rescan of your media library, after finishing the scan your index will be accessible.
jake-
garyo
[SOLVED] Re: 6.1 failing to create search index
That works, thanks!
These users thanked the author garyo for the post:
VikingOy
Has thanked: 3 times
Unread post by VikingOy »
Madevil wrote: Please stop the server and delete the folder from this path /var/madsonic/lucence3,
I have the same problem, but just to make sure; Is it the Album folder that should be removed from lucene3?
(ubuntu 14.4 server. I'm running 6.0.7860)
