6.1 External Player Support not working
fr500
Unread post by fr500 »
VERSION: MADSONIC 6.1 | BUILD: 8220
SERVLET: OTHER
SERVER: CPU: ICORE7 | ARCH: X64 | MEMORY: 4GB | HDD: 2TB
OS: UBUNTU 14.04
SYSTEM: SERVER
INSTALLER: DEB
JAVA: OPEN JDK 1.7
BROWSER: CHROME 44
CLIENT: WINAMP
DESCRIPTION: External player with playlist doesn't work
REPRODUCIBLE: YES (I reinstalled once to verify)
Clean installation on Ubuntu 14.04, just changed admin password, added a few tracks and tested.
I get an access denied error (tracks are with 666 permissions for testing)
Whenever I try to play using this mode I get:
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Bocanada
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Aquí Y Ahora (Y Después)
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Balsa
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Perdonar Es Divino
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Paseo Inmoral
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Tabú
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Río Babel
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Aquí Y Ahora (Los Primeros Tres Minutos)
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Verbo Carne
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Engaña
[4/26/16 6:47 PM] WARN SecurityService Unauthenticated access attempt: Puente
[4/26/16 6:48 PM] WARN SecurityService Unauthenticated access attempt: Puente
[4/26/16 6:48 PM] WARN SecurityService Unauthenticated access attempt: Alma
I tried this to test:
localhost:4040 /stream?player=2&id=31&suffix=.mp3
HTTP ERROR 403
Problem accessing /stream. Reason:
Access to file 31 is forbidden for user admin
Powered by Jetty://
and I tried authenticating just in case:
admin:mysupersecrepassword@localhost:4040 /stream?player=2&id=31&suffix=.mp3
And got the same
Nothing else was tweaked so I don't think the problem is on my end
These users thanked the author fr500 for the post:
MWerts
Re: 6.1 External Player Support not working
Unread post by MWerts »
I have the same, "extrenal payer with playlist", is not working al other players are working.
These users thanked the author MWerts for the post:
confirmed, will be fixed with next build. :)
rolandow
Unread post by rolandow »
I still have this problem on build 8660 .. is the bug solved already?
Issue is confirmed and will be fixed in the next release. :thumbsup:
