Is there a way to edit/ customize?
The .war file for tomcat being swapped out is not longer working.
Editing jsp files aka customization
Re: Editing jsp files aka customization
I spent the day trying the old method that worked before where you install, kill the jetty folder and then apply the standalone and let it rebuild the jetty folder so you can edit the .jsp files.
It doesn't work. Is there anyway to edit the current versions? I'll make a donation in hopes of an answer. It's the same old request now for years... Please let me edit the .jsp files. .. that's worth money to me.
(without learning Tomcat)
- Been thanked: 7 times
The source code is available in git if you are confident compiling and deploying yourself
