Madsonic Server 5.x KODI Plugin
Madsonic KODI Plugin
http://xbmc.org/
0.5.5:
  • Update for Build 5400
<playercorefactory>
    <rules action="prepend">
    </rules>
</playercorefactory>
Download
plugin.audio.madsonic.0.5.5.zip
(242.44 KiB) Downloaded 780 times
plugin.video.madsonic.0.5.5.zip
(242.42 KiB) Downloaded 615 times
Screenshot
cwalkpa2k
Rating: 15.38%
DoCC
Has thanked: 40 times
Been thanked: 65 times
Re: Madsonic Server KODI Plugin
Unread post by DoCC »
Nice idea, but ...
why should somebody install a mediamanager within an mediamanager ?
this is confusing to me : )
skopo
Has thanked: 8 times
Been thanked: 16 times
Unread post by skopo »
Song changing problem from XBMC Gotham remains.
Set play album -> 1st song no problems -> 2nd song not found -> 3rd not found -> rolls same way to the end of the album.
oxias
Unread post by oxias »
jmode wrote:Hi,
I would really love to use this add on in KODI but I keep getting the following error:
Incompatible Subsonic REST protocol version. Server must upgrade.
I get the error with both the demo server and my server.
Any suggestions?
Same problem reported, with a Subsonic server. I tried with a Madsonic Techdemo v5.1, but the add-on says 'time out"...
These users thanked the author oxias for the post:
cwalk
cwalk
Has thanked: 3 times
Unread post by cwalk »
I can use plugin.video.madsonic to play audio fine, but when I play video it will hang. Thoughts?
cwalk
slonlo wrote:Are you using Lollipop?
Nope. This happens on my KODI install for both Amazon Fire TV (based on 4.4.2?) and Windows. I haven't tried any other OSes.
What I do find interesting is that if I set transcode to false in plugin.video.madsonic\resources\settings.xml then I can play videos. Unfortunately, since I'm playing a RAW video, KODI/my network cannot keep up.
This leads me to believe that video transcoding is to blame, but I have no idea how to further debug.
