Android Player Compatability...
mlutzow
Has thanked: 10 times
Unread post by mlutzow »
Make the Madsonic Android Application be compatilble and installable on Visio Co-Star (Google TV).
Re: Android Player Compatability...
Do you get any error, infos or other messages ?
what device, type or model do you use?
mlutzow
No error messages, this is a Sony Co-Star which is the hardware for the Google TV system which is Android Based. I have the Play Store but a search for Madsonic will return zero results. Madsonic does not show up because Google for some reason thinks it's not compatible with the Google TV environment.
I could side load it, but I'm still researching how to root the device, which seems like that will be very difficult at this point in time.
I am able to get my videos to play on the TV (with Google TV) by using Chrome and openening the Madsonic Webpage but the streaming is spotty at best.
The Android Madsonic interface has so far provided the best results in an Android envirornment.
I'll get model number and other relevant information this evening when I'm finished working.
mlutzow
Sony Visio Co-Star
Model: VAP430
Firmware: 3.2
Build: US 3.0
Hope this helps
Mark
well i found the problem with the google store filter
https://developers.google.com/tv/androi ... atureCheck
i will fix this with next release
mlutzow
Thank you.
Next thing with this unrooted Google TV is I don't think I can get Java installed, still investigating.
I know it has Java Script operating.
****Edit to Remove Comments, MXPlayer just released a Google TV compatible version****
