Max bitrate - 5.0 Build 3840
bdavis0185
Unread post by bdavis0185 »
I posted this issue in another topic but figured I would delete that post and start a new thread instead of hijacking someone else and give more in depth information.
OS: Ubuntu 12.04 Desktop
Madsonic Version: 5.0 Build 3840
Installer: madsonic.deb
Issue: Max bitrate
#1 - When setting a max bitrate per user, the setting does not seem to saved. After saving the setting and returning to the edit user page, the max bitrate shows unlimited. When playing a song, it is not being downsampled.
#2 - When setting a max bitrate for the player itself, the setting does seem to save. After saving and returning to the player settings, the max bitrate is showing the saved setting (Example 128Kbps). However when attempting to play a song with that player selected, nothing will play at all. Upon changing the setting back to Unlimited everything works fine.
#3 - When using iSub on my iPhone, I have the max bitrate set to 128Kbps for cell coverage and unlimited for WiFi within the app itself. Upon attempting to play a song over the cell data, nothing will play. If I connect to WiFi everything will play fine. If I set the cell coverage max bitrate to unlimited, everything works fine.
I compared the Downdsample transcoding command between Subsonic & Madsonic to ensure they were the same, and they are.
Hopefully I can get some insight into this problem.
These users thanked the author bdavis0185 for the post (total 3):
Madsonicjk7grMetzlmane
Rating: 23.08%
jk7gr
Re: Max bitrate - 5.0 Build 3840
Unread post by jk7gr »
I have the exact same issue. Madsonic are you going to fix this on the upcoming releases?
