Humble requests
Posted: 28 Jan 2014, 21:55
by strawdragon
Hello.
I have a few humble request,
First:
I am using the API to update my database every 2 hours due to always being added throughout the day. It would be nice to be able to do that internally instead of passing HTTP traffic or cron.
Second:
Due to updating every 2 hours, my logs can get quite full. I would like to filter out everything but ERRORS and whom is playing what. Basically it would be nice to be able to disable the logging for DB scanning or have another Filter to select to just see who is playing what and when. Like of like what you see now when transcoding a file.
Third:
The ability to use the navigation slider to skip through a movie instead of the drop down and select at what minute interval to play from.
Fourth:
Ability to create a playlist for video files, instead of just music. I know you mentioned you will address this in a newer upcoming revision :)
