auto log in
columbiabbs
auto log in
Unread post by columbiabbs »
Hello all:
Is their a user log in that will work with Windows 7 x86 or Windows 2008 server?.This was the one thing I found missing with Subsonic. Thanks for any help. WT.
Re: auto log in
columbiabbs wrote:Hello all:
since Build 3820 you have three options to autologon.
1. Login and use the remember function (cookie)
2. Login with cleartext password Example: http:// yourserver.com/login.view?user=guest&password=guest12345
3. Login with encoded password Example: http:// yourserver.com/login.view?user=guest&password=enc:54205426560234532045765
chali
columbiabbs
Re: auto log in
Thanks for the reply:
I was asking about a auto log in for my users..
I run a BBS here in Columbia,SC and i would like a new user to be able to log in with out me have to add them one by one.
I found one for LINUX but not windows.
feel free to look at my site:
columbia.subsonic.org
guest/guest will get you in.
thanks for any help.
William T.
Re: auto log in
columbiabbs wrote:Thanks for the reply:
William T.
in your case you can try this:
http://columbia.subsonic.org/login.view ... word=guest
