Madsonic/Subsonic scrobbles songs to last.fm the very second you start listening to it. This is pretty annoying if you're skipping or checking songs.
This is a old issue, just musicCabinet is fixed.
Thanks.
Last.fm scrobbles
HeavensNight
- Has thanked: 4 times
- Been thanked: 7 times
Re: Last.fm scrobbles
I add this to the todo list, this should work for preloaded files too.
- Been thanked: 105 times
I think I saw somewhere in the settings (or maybe just read about it in the forums) that you can set last.fm to not scrobble a song until it has been playing for 30 seconds.
Now that I'm thinking about it, it may have been in the iSub app for the iPhone/iPad.
