[Build 3800] Missing tags on streamed mp3
Dyneslott
Unread post by Dyneslott »
Re: [Build 3800] Missing tags on streamed mp3
i test this with some mp3 and winamp as external player and have no problems.
tomdj
Unread post by tomdj »
Same here - no tags in foobar and in xion (only stream info).
Dyneslott
Metzlmane
Has thanked: 14 times
Unread post by Metzlmane »
Same here with .flac files.
I disabled all transcodings but i get only the stream?play.... with suffix=.mp3 ending.
I want to use foobar because i use a ASIO driver with it.
Any updates on this? I coudn't find a way to fix it myself :(
*Edit: It works if i'm using the admin account, but i can't figure out why. Seems there is another player created which is not listed in the player's section. which means i define player 6 as external player but the stream?player=5 is used.
