Add "New added" unders Songs on main screen of Android App
Posted: 27 Nov 2013, 22:26
by etyrnal
:idea: One feature i would LOVE to see (and i'll provide the reasoning for it), would be:
PLEASE ADD "New Added" under Songs in the main screen. Just like it is in albums how you can select "New added".
Reason: when i upload new songs to the server, i'd like the most recently added songs to show up when i click "New added" under Songs instead of having to hunt them down and create a playlist... or make an auto generated playlist called "Newly Added Songs" :idea:
Re: Add "New added" unders Songs on main screen of Android A
Posted: 02 Dec 2013, 17:07
by etyrnal
does anyone else see the value in this?
The purpose is this...
Say over that last few months you've added several songs to the server, and you'd kind of like to here those newer songs, instead of having to search for them one by one, and add them to a playlist, one by one... On the Madsonic Android Client, you'd be able to, under Songs, select "New Added", and it would add the most newly added songs to the play queue... the number of songs would be dependent on the "Search Display Settings", "Max Songs"
Decent idea??
Is there a way to make feature requests community-vote-able?
Posted: 02 Dec 2013, 20:46
is added with version 5.5, beta test start soon.
Posted: 04 Dec 2013, 01:50
by etyrnal
Madevil wrote:hi there,
Great! Super!!
Will version 5.5 (android) have to be purchased again?
Posted: 04 Dec 2013, 02:02
Great! Super!!
no, all updates are free on all stores! :D
Should i make a beta channel on the play store ? than people can join the early adopter test version.
Posted: 04 Dec 2013, 08:22
by rmnma
That is a very good idea!
Sent from my GT-I9300 using Tapatalk
Posted: 04 Dec 2013, 21:38
by mlutzow
Excellent Idea!
Posted: 04 Dec 2013, 21:43
