Android Client 5.5
additional Client information
Answers: 4
Has thanked: 1184 times
Been thanked: 465 times
Android Client 5.5
Android Client 5.5
Amazon App Store Link
Release Note
General
  • deep App Linking/Redirector
  • Mainview: new added Songs
  • Mainview: last played Songs
  • Update Madsonic Widgets
  • add Lockscreen Widget
  • add Theme Flawless
  • add Album Star Button
  • add Album Share Button
  • new search suggestion provider
  • support installation on Google TV
  • support Android 4.4+
  • Use Roboto Thin font (API 16+)
  • support serverside Lyric API 1.10.2
  • new Podcast View (add/remove only for Admins)
  • support Starred Items on Notification
  • support to show/hide Podcast/Search/Chat Tab
  • added more Links to Actionbar
  • updated Settingslayout
  • updated Themes
  • use Google Playstore Libaries
  • small Bugfixes
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
These users thanked the author Madsonic for the post (total 4):
ClayboymlutzowrZnlmike6453
Rating: 30.77%
Clayboy
Re: Android Client 5.5
Unread post by Clayboy »
Awesome can't wait... looks super slick.... do you plan on integrating pandora mode into the client or sunny theme.... i think that will push this app to the next level... good job your work is amazing
These users thanked the author Clayboy for the post:
imnotme
Has thanked: 4 times
Unread post by imnotme »
Hi, first of all thanks for a great product!
Is there anyway to have the player on the lockscreen?
imnotme
Looking great!
Answers: 4
other 5.5 Changes ...
Image Image Image Image Image Image
imnotme
Looks tasty!
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
Dumb question, but how do we auto-update this app from the Amazon store? I purchased 5.4 from the Amazon store since it was cheaper than Google. I can update other google apps fairly easily, but this is the only app I've downloaded from Amazon (other than Amazon itself), so I don't know how it can be updated....
Answers: 4
gurutech wrote:Dumb question, but how do we auto-update this app from the Amazon store? I purchased 5.4 from the Amazon store since it was cheaper than Google. I can update other google apps fairly easily, but this is the only app I've downloaded from Amazon (other than Amazon itself), so I don't know how it can be updated....
The App will update on both stores automatically, but 5.5 is at the moment in test-phase and will be released next week.
Clayboy
if you need any extra testers let me know... i literally use the app everyday
msndebord
Unread post by msndebord »
What's the status on pandora mode for the android client?
pajamas
Unread post by pajamas »
I love the beta app.
I had an issue trying to share, the link that it sent out had localhost:4040 instead of the link to my server. am I doing something wrong?
pajamas wrote:I love the beta app.
Try turning off Wifi and share over 3g/4g, or connect to a wifi that's NOT your home network.
raidflex
Been thanked: 6 times
Unread post by raidflex »
Any plans for adding the pandora feature that's in the main Madsonic interface?
pajamas
I tried on 3g/4g and on other wifi than my home and keep getting localhost:4040
GJ51
Has thanked: 42 times
Been thanked: 83 times
Unread post by GJ51 »
Check Settings/Network
You need to use an external URL, not localhost:4040.
The easiest way is to use a Subsonic vanity redirect URL
Access your server over the Internet using an easy-to-remember address.
http://servername.subsonic.org
Status: Successfully registered web address.
Then your links will look like:
http://corbinmusic.subsonic.org/share/ORnpm
rolandow
Unread post by rolandow »
I can't find the app in Google Play store if I follow the link in the OP.
Answers: 4
rolandow wrote:I can't find the app in Google Play store if I follow the link in the OP.
I'm sorry for the intricateness.
http://forum.madsonic.org/viewtopic.php ... 2504#p2498
baggar11
Unread post by baggar11 »
Hi Madevil,
New user to madsonic here and love it. Thanks for your work on the project. Currently, I'm using the subsonic Android app, but would love to support your android app. A couple people have asked about a toggle for pandora mode in the android, but has gone unanswered. What plans do you have for that? For me, that would be the one killer feature of the android app.
baggar11
binhex
Been thanked: 5 times
Unread post by binhex »
hi madsonic, just to let you know i purchased the android app via amazon and it works well :-). i have a feature request, dont know how difficult this is but would love the ability for madsonic android app to detect if your connected to your home wi-fi or not, if you are connected then automatically use your internal server details, if on 3g/4g then use remote server details.
at the moment i need to remember to switch my server connection when home, and the same when im out and about, would love a more intelligent (automated) way of doing this.
skopo
Has thanked: 8 times
Been thanked: 16 times
Unread post by skopo »
binhex wrote:hi madsonic, just to let you know i purchased the android app via amazon and it works well :-). i have a feature request, dont know how difficult this is but would love the ability for madsonic android app to detect if your connected to your home wi-fi or not, if you are connected then automatically use your internal server details, if on 3g/4g then use remote server details.
I have been playing with these a lot. How your local and remote adress are different from each other?
