Have you considered making an IOS version of the client?
I just send a little bribe to make you think on it
Looks very nice testing right now.DarthNerdus wrote:I just release a new iOS Subsonic client called Audiophone on the App Store. I'd link it too you, but unfortunately the forum thinks that's a little too spammy.
Thanks for the compliments!skopo wrote:Looks very nice testing right now.DarthNerdus wrote:I just release a new iOS Subsonic client called Audiophone on the App Store. I'd link it too you, but unfortunately the forum thinks that's a little too spammy.
Support for folders and playlists needed so far.
Sorry to hear that you're having issues connecting, would you mind reaching out to support@audiophoneapp.com? I'd love to get more information about your setup and try to sort out what's causing the issue.rixton wrote:Looking forward for folder-base navigation!
It does work fine using my external IP, but when I try connect to my server by any of my hostnames (x.subsonic.org, my private .org domain, or dyndns.org adresses), it just states "Login failed."
Works fine using both the webrowser and iSub with the same adresses
Thanks for the input, I've added your +1 to the feature request.triptol wrote:Video support. I am on the road a lot and I use madsonic to watch my series in hotels on my iPad. I could switch to plex for that, but I don't like their security model (having user authentication in the cloud is probably the dumbest security decision I have seen in the last years).
