share file not found error
Re: share file not found error
go to settings -> network
check your url path settings and correct port -> press save
try again
try again
I have had that also. I switched to the other network card on my PC and they seem to have gone away so I am guessing it was dropping the connection. I usually fixed it by disabling/enabling the connection and then I had to sign back into the NAS.
