Broken images in Status tab and User Statistics
boulund
Unread post by boulund »
Hi!
I tried looking through the bug reports for something similar but couldn't find anything. This issue has been with me since I started using Madsonic at build 3660, and is still there in the most recent build (3740) that I just installed. Everything else works perfectly and I'm very happy with my switch from Subsonic (been using it for many years now).
The attached image shows the symptom. When right-clicking a broken image and opening it in a new tab you see the following java error message (entire message):
 Error
Exception	java.lang.NoClassDefFoundError
Message	Could not initialize class sun.awt.X11FontManager
Java version	Oracle Corporation 1.7.0_40
Operating system	Linux 2.6.37.6.RNx86_64.2.4
Server	jetty/8.y.z-SNAPSHOT
Memory	Used 90 of 247 MB
Stack trace	java.lang.NoClassDefFoundError: Could not initialize class sun.awt.X11FontManager
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:270)
	at sun.font.FontManagerFactory$1.run(FontManagerFactory.java:82)
	at sun.font.FontManagerFactory.getInstance(FontManagerFactory.java:74)
	at java.awt.Font.getFont2D(Font.java:490)
	at java.awt.Font.defaultLineMetrics(Font.java:2175)
	at java.awt.Font.getLineMetrics(Font.java:2245)
	at org.jfree.chart.axis.ValueAxis.findMaximumTickLabelHeight(ValueAxis.java:869)
	at org.jfree.chart.axis.ValueAxis.reserveSpace(ValueAxis.java:809)
	at org.jfree.chart.plot.CategoryPlot.calculateRangeAxisSpace(CategoryPlot.java:3446)
	at org.jfree.chart.plot.CategoryPlot.calculateAxisSpace(CategoryPlot.java:3465)
	at org.jfree.chart.plot.CategoryPlot.draw(CategoryPlot.java:3510)
	at org.jfree.chart.JFreeChart.draw(JFreeChart.java:1235)
	at org.jfree.chart.JFreeChart.createBufferedImage(JFreeChart.java:1409)
	at org.jfree.chart.JFreeChart.createBufferedImage(JFreeChart.java:1389)
	at org.jfree.chart.ChartUtilities.writeChartAsPNG(ChartUtilities.java:183)
	at org.jfree.chart.ChartUtilities.writeChartAsPNG(ChartUtilities.java:136)
	at net.sourceforge.subsonic.controller.UserChartController.handleRequest(UserChartController.java:66)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:686)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1494)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1482)
	at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1474)
	at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:489)
	at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:949)
	at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:1011)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:668)
	at java.lang.Thread.run(Thread.java:724)
I tried my hand at googling for a solution to the sun.awt.X11FontManager not found error but haven't found a solution that worked. I tried making sure that I have the latest Oracle Java installed (1.7.0_40), both the JDK and the JRE. They are both available in $PATH. Most findings point to Deja Vu font not being installed, but I installed it by hand (not available in old Debian repo) and checked that it is listed in fc-list.
Has anyone else encountered this and found a solution?
For completeness: I am running Madsonic 3740 on a Netgear ReadyNAS Ultra 2 (x86) with Debian Linux (4.0) with 1 GB of RAM. Oracle Java version 1.7.0_40, with both the JRE and JDK bin-folders available in $PATH.
Broken images
Broken images
