id3 auto tagging
Posted: 04 Oct 2013, 04:41
I'd like to see a feature that will allow Madsonic to automatically tag an entire music library with a specific ID3 tag format, and apply it to all albums, artists, and songs. It should rename files and paths, as necessary, or provide the option to do so.
Would also like to see a better way to pull lyrics from the web, or if they are embedded in the id3 tags, to just use that instead. I have a bunch of music with the lyrics embedded, but Madsonic still searches the internet for lyrics, and many times, it either doesn't find lyrics, or it finds the wrong lyrics.
