default list when changing folder [solved]
Posted: 16 Sep 2013, 16:35
by TheWarden
When you change folder from the drop down it is not respecting the preferred list (always using random) nor the custom row/column. You have to click on "Home" to get it to update the current folder to the custom view. Minor but a little annoying when switching through folders.
Thanks for the great work!
