Subsonic Clients w/Madsonic Server 5
Posted: 01 Sep 2013, 21:44
Is Madsonic Server 5.0 Beta5 Build 3600 supposed to be backwards compatible with Subsonic clients (specifically on Android)? I cannot get it to work with either the standard Subsonic or Ultrasonic Android clients. I can browse the library but nothing will play.
On Madsonic server, the log reports:
[9/1/13 3:22:10 PM CDT] INFO PlayQueueInputStream texneus listening to "Farewell To The World/18 Weather With You.mp3"
[9/1/13 3:22:10 PM CDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/NetworkMedia/Music/Main/00CDs/Crowded House/Farewell To The World/18 Weather With You.mp3] [-ab] [64k] [-v] [0] [-f] [mp3] [-]
[9/1/13 3:22:10 PM CDT] WARN RESTFilter Error in REST API: broken Stream
On Subsonic the file appears to download anyway (but will not play). The subsonic demo server works fine.
On Ultrasonic I don't get the WARN in the log, but otherwise it looks the same. It does not appear to download the song and does not play anything either.
One thing I have noticed which may be confusing the players is they report the stream is 320kbps mp3 (source file format) even though it is transcoding the file.
Server is installed on a clean Debian Wheezy install via the .deb package and Oracle java 7.25 (in a Virtualbox VM for testing). Audio plays fine in the Madsonic web interface on a remote PC.
