Beta 5 3600 "Random" bug
Posted: 29 Aug 2013, 02:51
Just updated to the 3600 beta5 version, and as soon as I login, I go to the "Home" screen (as I have always done in the past), and it would default to the "random" screen, and show a list of random albums.
But with this version, if I have a folder set selected to anything other than "All Folders", I see NOTHING under the random list. I do see albums under "New", etc..., but nothing under "Random" unless I select "All Folders".
I'm trying a media folder rescan now to see if that helps....
Edit: Yep, that was it. Do a full media scan (the first option from the list "Scan Media Folders Now" will suffice).
