Download Function and Asian / Unicode Characters in Filename
Posted: 28 Aug 2013, 23:35
by BKKKPewsey
See
http://forum.subsonic.org/forum/viewtop ... =15#p46203
Just did a quick test on Madsonic version 5.0.3510.beta3 and the same problem exists
eg all unicode characters are replaced with ? within the zip file.
e.g. "01. Девчонки олигархов.mp3" ends up as "01. ???????? ?????????.mp3"
PS Madevil welcome back from the holiday - you didn't spot Hakko on your travels -he last logged in on 21st May - thats some holiday
Re: Download Function and Asian / Unicode Characters in File
Posted: 28 Aug 2013, 23:42
BKKKPewsey wrote:See
Thank you
yes holiday was really necessary
This request should be fixed with Beta5
Info About last Build
http://forum.madsonic.org/viewtopic.php?f=16&t=14
http://sourceforge.net/p/subsonic/code/3495/
PS: No Sorry ! No trace of Hakko
Posted: 29 Aug 2013, 10:20
by BKKKPewsey
O.K. I tested with the new 5.0.3600.beta5
Some success in that the filename for the zip is now showing the correct unicode characters eg "2012 - Intimnepredlagat (Интимнепредлагать).zip" instead of "2012 - Intimnepredlagat (-----------------).zip"
however
the files within the archive are still showing ???? as before
Note I am using 7-Zip(Windows) to read the archive but I know that program has no issue with unicode characters in archives it creates.
