Seeking/offset and timeline bug
Ricky1252
- Has thanked: 4 times
- Been thanked: 7 times
Well This is the best way I can describe it anyway. Basically from what I can tell, while flash player is playing the movie, the current time and total time remain at 0:0, as well in the drop down box the for offset seeking option show nothing when clicked. I upgrading from 3510 to 3572. Ill look deeper into this when I have time tomorrow or later on in the week.
Ricky1252
Re: Seeking/offset and timeline bug
Well, I'm not sure what the problem was, but I restarted the server with build 3510, and it didn't happen. So I switched back and it was working properly. I changed some equipment around before this problem happened so perhaps it was more of on the hardware side or something. XD anyways, the problem is resolved. =]
