Artwork subfolders considered albums
Posted: 29 Jul 2013, 20:06
by pa2k
Hi, I recently switched to madsonic (3350) from subsonic (4.8), and am having an issue that I can't recall experiencing on subsonic.
My music library is primarily sorted \Artist\Album, though in many cases there are also subfolders named "artwork", "scans", "cover", "booklet" etc.
At the home>random screen (which I mostly use) oftentimes these subfolders show up as such:
- which is inconvenient as clicking them leads not to the music (circled in red below) but to the subfolder (crossed out):
Before I engage in a suboptimal brute solution such as merging all artwork folders with their parents, I figured I'd check if this is easily solved some other way or on the madsonic to-fix list?
