Hey there,
I found a little bug with the Icons that are displayed at the top of the page. Editing them with an admin account to following:
doesn't have any effect for other user accounts:
But checking the box "use settings also for admin accounts" works, but only for admin accounts, other users remain unaffected:
Commanche
Icons
Re: Icons
Running on Madsonic Server 5.0 Beta5 Build 3600 and the problem still exists.
Also noticed "If I put away "History", it dissappears on the adminpanel, even if "use Settings also for Admin Accounts" is not set".
Re: Icons
I posted about this issue a few months ago in the Help forum:
http://forum.madsonic.org/viewtopic.php ... 1519#p1519
It's been broken since at least 5.0.3510.beta3 and I can confirm it's still broken in 5.0.3600.beta5.
- Been thanked: 3 times
Re: Icons
New installation of 5.0.3800 and the problem persists.
Unchecked quite a few icons in the Settings -> Icons page. But, the icons show up for admins and non-admins. The only way to get the unchecked icons to not show is to check the "use Settings also for Admin Accounts" checkbox. However, this hides the icons for all users - admins and non-admins.
Thanks,
MediocreFred.
Thanks,
MediocreFred.
