UBUNTU: Madsonic Server 5.0 Beta3 Build 3500 Fails To Start
Posted: 07 Jun 2013, 20:23
I am currently running Madsonic Server 5.0 Beta2 Build 3480 on a headless Ubuntu 13.04 64bit server with NO ISSUES.
Today I downloaded and installed the latest .deb for Madsonic Server 5.0 Beta3 Build 3500.
I skipped over Madsonic Server 5.0 Beta2 Build 3490 since there was no .deb for that build.
I backed-up and uninstalled Beta2 and then installed Beta3 from the .deb file.
I have Oracel Java 7 installed which solved many issues on Beta2
I followed the steps here - http://www.webupd8.org/2012/01/install- ... u-via.html
I can start subsonic (madsonic)
But I cannot connect to it via web browser from a remote machine. I get 503 Service Unavailable (I am on a headless server)
To check if it was running I typed:
I can see in the list of services that subsonic is NOT running
I have reverted back to Beta2 with no problems.
Any ideas?
java version "1.7.0_21"
Java(TM) SE Runtime Environment (build 1.7.0_21-b11)
Java HotSpot(TM) 64-Bit Server VM (build 23.21-b01, mixed mode)
sudo service subsonic start
Started Subsonic [PID 18276, /var/subsonic/subsonic_sh.log]
sudo service --status-allCode: Select all
[ - ] subsonic
Any ideas?
