Just look at downloads and saw that 3360 src was released! So excited and then dependency error booo! =[
Failed to execute goal on project subsonic-main: Could not resolve dependencies for project net.sourceforge.subsonic:subsonic-main:war:4.8.beta3: Failure to find net.sourceforge.subsonic:subsonic-lastfm-java:jar:0.1.6-SNAPSHOT in http://repository.springsource.com/mave ... es/release was cached in the local repository, resolution will not be reattempted until the update interval of com.springsource.repository.bundles.release has elapsed or updates are forced -> [Help 1]
3360 src error building =[
Re: 3360 src error building =[
Hi Ricky,
yes the build is a little tricky
i send you the latest Snapshot, extract all sources and build as follow
:: standalone ::
CD %sourcePath%\subsonic-booter
mvn install -DskipTests -q
:: java-LastFM ::
CD %sourcePath%\subsonic-lastfm-java
:: main ::
CD %sourcePath%\subsonic-main
:: installer ::
CD %sourcePath%\subsonic-installer-windows
Hi. I got this same error attempting to build from source. It appears that the source for "subsonic-lastfm-java" is missing from the source download...
Is it possible to get the source for the missing module?
Regards,
Bruce
Regards,
Bruce
hi,bwood wrote:Hi. I got this same error attempting to build from source. It appears that the source for "subsonic-lastfm-java" is missing from the source download...
Regards,
Bruce
i send you a new one (PM), this version should have all needed references as described above.
