I have implemented the use of ssa/ass A bit more user friendly guide for subsonic/madsonic and I request src to add a bit of code for my method to work. Currently im stuck using 3180, which I love! however, upgrading would allow me to see more amazing development, and that would be great! =) Ill explain the proccess in hope its added or grant me access to src so I can add it myself for new releases.
First off the code I require is in transcoding service, basically need basefilename the way i implemented it
more or less I added this at the beginning on the interpolation strings
String filenn = mediaFile.getName();Code: Select all
if (cmd.contains("%f")) {
cmd = cmd.replace("%f", filenn);
}ffmpeg will need to be upgraded to have --enable-libass. Recompile or download a compiled version of ffmpeg with --enable-libass and of course place it in the transcode folder.
Although there is many ways to do this next part, the easiest route would be creating a folder for your subtitles. I created a folder called sub for my ass/ssa subtitles... /var/subsonic/transcode/sub
The ssa/ass subtitles require to be manually placed here. If there is no file for said video, it will not play. Of course I have a workaround for this.
Creat a file named clean.ass.
clean.ass
[Script Info]
ScriptType: v4.00+
[V4+ Styles]now for transcoding... note, I only use this for mkv's.
step 1 - workaround for no ass file...
ffmpeg -i /var/subsonic/transcode/clean.ass -n /var/subsonic/transcode/sub/%f.assCode: Select all
ffmpeg -ss %o -i %s -b %bk -s %wx%h -copyts -af asetpts=PTS-%o/TB -vf ass='/var/subsonic/transcode/sub/%f.ass',setpts=PTS-%o/TB -ar 44100 -ac 2 -v 0 -f flv -vcodec libx264 -preset superfast -threads 0 -and ta da! done! you now have working ssa/ass subtitles for Subsonic/Madsonic.
One last thing I want to note, fonts may need to be added for some of the subtitles to work properly. Iv only done this on linux. Any with questions or comments please ask away and ill be happy to answer or help! =]
