Is it currently possible to play videos within the app? If not, would it be possible to add that functionality?
Play videos within app?
- Has thanked: 2 times
- Been thanked: 1 time
- These users thanked the author fishnet37222 for the post:
Re: Play videos within app?
hi there,fishnet37222 wrote:Hello,
there will be come more ... maybe also a vlc emmbed solution?
at the moment on the android there is only a redirect to the server flash or html5 interface.
but you should get more option in the near future
Sindre has also adanveced the Server interface http://sourceforge.net/p/subsonic/code/3421/
TODO IN ANDROID 3.8
Video: Test MX Player
Add video alternatives: Flash, HLS, native
... with the Android 5.2 Build you can choice if you want the serverside Flash Player or an selectable external Player (MX Player, VLC, ...)
