jquerry-ui accordion adaptation
ForSSux
Has thanked: 10 times
Been thanked: 12 times
Unread post by ForSSux »
In the link http://jqueryui.com/accordion/#no-auto-height you provided I found this ..heightStyle: "content"
I think it can serve to help me with the problem of the space under the items in the accordion
A picture speaks a thousand words so
At the same place they talk about hover and opening ....this would be great to.
I looked in the default.css and in a jquerry-ui-1.10.2 custom.css but have no clue where to add the heightStyle: "content"
Thanks for reading
Guy Forssman
Re: jauerry-ui accordion adaptation
whats about
  $(function() {
    $( "#accordion" ).accordion({
ForSSux
ForSSux
I'm sorry to trouble you again
$(function() {
Can I just add this function in a .css file? Which file is the most approriate to add this function or if it's in place which file holds it.
software# grep -R "#accordion" /var/subsonic/jetty/3470/webapp
/var/subsonic/jetty/3470/webapp/WEB-INF/jsp/left - Kopie.jsp:        $("#accordion").accordion( {active: true, autoHeight: false, navigation: false, collapsible: true, icons: icons} );
/var/subsonic/jetty/3470/webapp/WEB-INF/jsp/left.jsp:        $("#accordion").accordion( {active: true, autoHeight: false, navigation: false, collapsible: true, icons: icons} );
so I assume I add this function in left.jsp?
Kind Regards
Guy ForssmanI
