Problem with Share...
Posted: 22 Mar 2013, 10:02
by Ghizmo
Hi all,
The sharing option was working for me until now... I've now a problem : when i click on "Share" i have a link like that "{0}" with an URL http://"mydomain":4040/%7B0%7D
Someone have an idea for resolving this ?
Thanks in advance...
Re: Problem with Share...
Posted: 23 Mar 2013, 07:41
by GJ51
No - I have never seen anything like that.
It might be helpful if you provide more details about your platform. I have no issues like this on Windows, but the Linux world is a whole different ballgame.
The more details you share, the more likely someone may be able to help.
Have you looked for any entries in the logs that might be helpful?
Posted: 23 Mar 2013, 17:38
by gurutech
Does this issue affect all users, or just you (or a single user)?
Try disabling sharing for this user (or for all users), then save changes, then re-enable and save again. Sometimes configuration files can become partially corrupt, and resetting a setting or two will fix it.
I've never had any sharing issues on my end, and I'm running Linux, so I don't think it's an OS issue though.
HTH
